The tensioner is $350.00 + shipping.How much for the tensioner? Where can I buy one?
I'm surprised that the bolt pattern of the RR tensioner doesn't match since I have one here and I was using it on mine till I bent it.I have a 2002 GT with a 2.6 and 3 bolt tensioner (99 cobra front cover).
I have already tried the RR tensioner . Bolt pattern does not match.
I need something. I have a bent tensioner. Will this work for my situation..
THanks
You should be in good shape once the larger idlers are in place. Those are what I used to give me a bit more clearance.With my Kenne Bell and 8 rib kit the black screw on the tensioner is only 3/8" away from the stop, we will be tuning it next week and wondering if that is right. I will be adding a 100mm idler and 2-90mm, 1 on the front cover the other on the tensioner to try and take up some belt slack
Glad to see you like it David.Peter,
Just wanted to let you know the tensioner is still holding up great! Ran a 10.72@124 this past weekend...1.48 60'. Whipple HO 12 psi.
Thank you for a great product!
Metco was asking my buddy who made the tensioner, but he couldn't recall "Thumperrr" and didn't know your name.
Been putting it to the test for sure!
You don't need to change anything else.forgot my set up 07 gt 2.6l kb on stock pullies, would i need to change anything else thanks
