clutchless auto with paddle shifters......
this article used to have a video along with it but i can't find the video. It's still a great article describing the starting line and what affects what.
http://www.summitracing.com/expertadvice/storydetail/howtos/how-to-stage-your-drag-car/
another cool article
http://www.summitracing.com/expertadvice/storydetail/howtos/how-to-bracket-race/
reaction time should really be prediction time. If you react to the green lght you are toast, you are actually trying to predict when the green comes on in relation to when your tires unblock the beam.
Stagger of the front axles also effects rollout.
Some tracks don't allow you to drive around the water box, in that case at least try to do a burnout far enough to get the water off the track.
My rhetorical questions,
"what does in the groove mean?"
"what is burning down the other guy?"
Another term people may not know is courtesy staging. Courtesy staging is when one car turns on the pre-staged bulb and waits for the other to turn on their pre-staged bulb before turning on their staged bulb. At some tracks, the starter will back you out if you "double-bulb" the other racer and tell you to wait until the other guy is pre-staged. It is considered rude to turn your pre-staged an staged bulbs on before the other guy even gets his pre-staged bulb on.
Yep, in some races they enforce courtesy staging by DQing you if you double bulb.
Not a dumb question. For me, I could care less. I have a routine and stick with it no matter if you double-bulb me or not. Once both cars are pre-staged and then one of the cars gets staged, the other car has 7 seconds or somewhere around that to get staged or they will be DQ'd. Some people are bothered by double-bulbers because they lost that time that it takes for the other person to stage. so instead of 10-15 seconds to get staged, they now have 7 seconds. If you race at the same track a lot, you'll learn who doesn't like double-bulbers and you can use that to your advantage. If I'm against someone who I know hates double-bulbers, I'll get pre-staged then bump in a few more times to the point where my staged bulb is almost coming on. As soon as the other person pre-stages, I'll bump again to turn on the staged bulb. Racing is sometimes more mental than anything else.My dumb question, what is the negative for one guy sitting staged while the other takes his time to stage, why DQ the guy that is staged and waiting?
Do u put it on top of the S/C case or on the CAI connecting tube?Paul, I've actually been doing exactly that the last few times out. Works great for cooling down the blower. I get lots of funny looks when people see the big Ziplock bag on top of the motor but that's ok.
On top of the blower itself. My motor doesn't get that hot, and the coolant reservoirs from the radiator and intercooler are both lukewarm at best but the blower itself gets hot. I can melt two quart size ice blocks in an hour and it will still be warm to the touch.
Thanks for the response. Can anybody confirm it helps ET's?I think it does, but that's a subjective opinion and I can't back it up with proof.
I agree with everything you said with the exception of 11.5". It isn't always 11.5". A 26" tall tire is going to have less rollout than a 28" tall tire. Air pressure also causes a variation in rollout. This is why you typically see people adjusting the air pressure in their front tires in the staging lanes, not just the back tires. They want their car to have the same rollout every round.
Summit Motorsports Park did a cool video describing rollout, I'll have to see if I can find it.
