Why did you delete all of my answers? Weird.
I was editing all of the other posts, and I accidently edited yours when I meant to quote it.
I don't have a question as much as I just have a statement to make to first time racers. Please don't drive though the water box with your front tires if there street tires. Drive around and back into the water. Idk how many times I've had cars with street tires pull water up to the beams and mess things up for me.... /end rant
so you were a "catcher"?
How about these ones.
You know how many people actually think reaction time affects your ET? How many of you know exactly how the timing system at the starting line works?. How many of you know exactly what rollout means, and how tire height, even air pressure, can affect it? How does shallow staging and deep staging affect your ET and reaction time at the track?
There is a few. Who has the right answers? Lets see. Marc S don't answer.
It depends on your class. I have seen .400 protree, .500 protree, and .500 three amber.
Protree= all three yellows come on at the same time
3 amber = each yellow comes on separately for .500 seconds.
no way....Here is one for you..........
Should I do painted on or sticker racing stripes? I dont want the lip from the stickers to affect the aerodynamic drag so Im thinking Ill have them painted. What do you think?
true story........ I have yet to reply
ive done both... my car rolls my buddied 2000 i drove a few times didnt... bobs GT500 doesnt roll.for the five speeds, do y'all hold the brake and sidestep to prevent any rolling or do you just sit there with the clutch in like i do until the green light? i shallow stage by the way, and like someone else said they won't let you around the water so i try to take my time getting to the line and if other guy is slow i'll back up and do another burnout.
Good thread if it stays on track.
Copy and past because im too lazy to type it myself,
The term "rollout" might not be familiar, but it comes from the drag strip. The arrangement of the timing beams for drag racing can be confusing, primarily because the 7-inch separation between the "pre-stage" and "stage" beams is not the source of rollout. The pre-stage beam, which has no effect on timing, is only there to help drivers creep up to the starting position. Rollout comes from the 1-foot separation (11.5 inches, actually) between the point where the leading edge of a front tire "rolls in" to the final staging beam — triggering the countdown to the green light that starts the race — and the point where the trailing edge of that tire "rolls out" of that same beam, the triggering event that starts the clock. A driver skilled at "shallow staging" can therefore get almost a free foot of untimed acceleration before the clock officially starts, effectively achieving a rolling-start velocity of 3-5 mph and shaving the 0.3 second it typically takes to cover that distance off his elapsed time (ET) in the process.
Automaticheres a good one. define power shifting.
