conexion914
- Joined
- Aug 25, 2011
- Posts
- 303
- Reaction score
- 0
Get a true trac or a Detroit locker unless you plan on trailering the car and only driving it in dry weather.
your car a 5 speed?
if anybody has a truetrac or knows somebody let me know.. thanks
well went to the track yesterday and broke my spider gears, i knew it was commin and the track was on point yesterday and a 5k clutch dump on a radial got em right there on the line. I will be most likely switching to an et drag now stiff wall slick, and just wondering what to do about my differential... I've heard true track is decent, and spool is great for the track but not so sure about the street.. car is 2010 gt mostly street car.. what do you guys think?
So looking at the TrueTrac, Eaton claims it comes in 31 spline and 33 spline - http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_128302.pdf - do they have a 35 spline and not list it? I remember 35 splines are available from Moser and a few others, but haven't seen much in terms of lockers for those bad boys... Or is 33 spline as good as it gets? I imagine a whipple 5.0 on slicks, or a gt500 could still break a 33 spline axle... Not that I'm gonna get anywhere close to that kind of power, but I like to go overkill with stuff when upgrading![]()
33 spline is it for the 8.8 TrueTrac and Lockers, Breaking an OE 31 spline axle isn't as common as you'd think with these heavy cars.
I'm running Strange 31 spline axles and their wheel studs and had more trouble bending rear wheel studs, I'm on my 3rd set.
