track guys analyze my time slip please
BAD GT
lindenhurst NY
went to the track fri night
i think i should be in the 11's.
is my problem getting out of the hole to slow.
what do you guys think?
here is my mods
automatic
10# procharger
410 gears
tune
mac cat back
nittos 28" tall
440 rwhp
car weighed 3800 (w/ me in it)
time slip
68 degrees
bar 29.45
r/t .455
60' 1.908
330 5.15
1/8 7.86
mph 89.35
1000 10.23
1/4 12.22
mph 113.85
TGJ
Regina, Saskatchewan, Canada
here is my mods
automatic
10# procharger
410 gears
tune
mac cat back
nittos 28" tall
440 rwhp
time slip
68 degrees
bar 29.45
r/t .455
60' 1.908
330 5.15
1/8 7.86
mph 89.35
1000 10.23
1/4 12.22
mph 113.85
Yes, you need to get out of the hole quicker. If I were you, I would consider a different tire than the Nitto's and I would look into a 3500+ RPM Stall TC. That should get you down to a 1.6 - 1.7 60' and you will see 11's.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I would agree... assuming the Nittos are not hooking.
Also, how are you launching the car? Are you powerbraking at all, or launching from an idle?
ranebowcyxx
Wow, very smlar to my numbers with 10 PSI on a PC. I just wasn't making enough power until I got some boost.
I agree, a 3500 stall should get you where you want to be.
95PGTech
SN95s > all
Levittown, PA
Your problem is the procharger :beer:
You have to remember a centri makes its power way up top, get yourself a looser converter so you can launch it closer to the maximum torque rpm. If you're stuck with the Nittos run them around 17psi, get yourself an adjustable rear shock like a QA1, and do a John Force burnout. 555R's only work when you get a ton of heat in them.
If you don't want to drive a converter that loose, get a Saleen blower. On 10psi you'll easily be in the 11s and that converter you have now will be just perfect for it.
don_w
San Diego, CA
+1 on the burnout with DRs... you need to smoke them really well.
Also, launching at 1100 rpm isn't helping you. Bring that thing up as far as you can without it rolling on you. With the stock converter that should be in the 1800-2000rpm range. I've gone as low as a 1.54 60' on the stock TC, and 1.60s-1.70s were pretty common.
-1 on the Saleen SC... get a KB. :moon:
US-1
Banned
The ShadowLands
I concur. Taking too long for the Procharger to build power with you leaving at 1100 rpm.
BAD GT
lindenhurst NY
thanks for all the replies guys.
im very happy with the procharger , not looking to switch.
i will see about getting a converter and a deep pan with a catch can for the auto.
thanks for the tips with the drag radials.
US-1
Banned
The ShadowLands
Quick word about converters. I ordered the PI 3500 and told them everything about the car but I missed on the rpm that I really needed. The converter will only go to 2500 rpm or so on the footbrake. If you need 3000 rpm on the footbrake then tell them that when you order. We don't have time to take it out and wait for it to come back so we're buying another one.
Figure out where the Procharger starts making power and make that your rpm you need on the footbrake.
95PGTech
SN95s > all
Levittown, PA
don't get a deep pan, waste of time. puke tank, converter, tune is all your transmission needs. I've seen so many over or underfilled transmissions because of deep pans it's not even funny.
Fastmover
MD
+1
I got 10ish pounds, been 11.33 with weak 60 foot. Still running 2 piece drive shaft and full 60 lbs. 20s on the front!
95PGTech
SN95s > all
Levittown, PA
Supporting modifications. shrug.
I would hope someone wouldn't try and throw 10psi on a stock motor, stock maf, stock injectors
