Did they have scale there? I meant to ask/look and forgot, I wanted to know what the car weighs.
I know you weren't being a jerk...and agree with my 60's I was not getting into the 10's that day. I need to figure out my burnout issue as with slicks and an automatic there is no reason I should not have done better than I did.
Line lock is in the garage to be installed, SFC's, A2A setup and a PA pan to get another 4 qts of fluid in the tranny are all on the sked to be installed over the winter.
Also picked up a set of Greg Weld skinny fronts to reduce rotational mass on the front.
I was very impressed with the weight of your car, the dyno numbers and the low number of mods you have done to get the time you ran, more disappointed in my setup.
Greg,
I think you are being to hard on yourself, you did a whole lot of changes to your car in a short time frame. You just have to get it sorted out and it sounds like you are addressing it. The line lock will help a bunch for your burnouts. Don`t be too disappointed, once you get the setup straight and seat time you will be in the 10`s easy even w/ no addnl power added. There is a scale at VMP, its to the right of the time slip booth and just after it. Good luck man, again if I can help just let me know, you know where to find me.
