wicked stang
Installed the truetrac that I bought new from a member on this forum along with new gears and all new bearings and races a couple months ago. Took the cover off today to change the fluid and make sure there were no metal shavings. Instead of any shavings I found big chunks of metal...
The edge of the truetrac housing/body on the passenger side had big chunks missing that were laying at the bottom of the axle housing. All of the side cover bolts into the truetrac were loose enough that I could turn them by hand. So it seems like the bolts loosened up enough for the side cover to shift around and bust the edges of the housing off. Was doing a bit of searching and it seems like the bolts coming loose is pretty common for some other vehicles with trutracs.
Going to call eaton this morning to see what they say but I'm not sure it will be warrantied. How would you guys go about fixing this? I have a buddy who is an awesome welder and could tig the pieces back on for me and I can loctite the hell out of the bolts. There doesn't seem to be any other damage to the gears or bearings and hoping nothing is damaged inside the diff. I didn't hear any clunks or unusual noises so I don't know how long it has been like this.
Here are some pics with the areas that are missing material circled in red.
