tuning issues
05stroker
Never enough power guy!
Bullard Tx.
If it turns out the a b s module is bad I've got one I removed from my car l would sell cheap.
Dillon Dollar
oklahoma
Maybe, if want to change it, IIRC you only need the electronics as the pump body is the same.
Edit: In the mean time you could have your tuning process done with it unplugged and then reconnect and see how it goes.
Okay so I only need thr electronics that makes it simple, and I think somehow during all the crazy ness of it not working the aftermarket tune is not my factory tune , because the car runs better on the factor than the custom tune lol
lito
Caracas, Venezuela
It happens, lol.
lito
Caracas, Venezuela
ABS IC and PCM share a high speed CAN bus, these are the lines used to send data over the PCM for flashing. If the ABS is messing with this bus it can make this happen.
Dillon Dollar
oklahoma
Well very nice glad that its finally figuredl out, if only I could have a tune now they don't gave an opening until the end of june -_-
I have had an abs light since my upr k member swap, havent been able to figure out the cause. No issue loading tunes though although it does fail to see key on everyonce in awhile so I have to do it over. Did the the abs light go out when you unplugged the abs module?
Dillon Dollar
oklahoma
No it did not the e brake light actually came on aswell but I'm going to trt and get that module from stroker and see if it fixes the problem
How long as your abs light been on? I havent been able to find a place localy that has the tool to read abs codes.
My traction control is permanetly turned off in the tune and has been for years. I know my tuner does it all the time automaticaly.
