Tuning problems p060c code
Arizona
So, I have my car off at my tuner, He had the tune almost done, and the car was making good power, when he went to make a slight change the car's tune got corrupted/he lost it, and i get a call today saying that he is getting this p060c code, and that it is corrupting the files for the tune, i have a GT with the saleen supercharger, and I know the stock ecu got flashed by them, but he was having problems reverting it to stock tune off of my sct tuner (stock meaning the saleen tune), he tried unmarrying the sct device because we are tuning with Diablosport, and i believe got a similar code again. I believe his course of action is to try to find a stock flash, (idk if possible), or a new pcm. What do you guys think? ever hear about this before? Im writing this with somewhat limited information and in layman terms so forgive me if im forgetting something that i dont understand or know.
cmrad
shit i hope they fix this issue in the most cost effective manner for yourself, as to insight about the issue i have no idea, hopefully some of the other members with more experience/knowledge will chime in.
Alfiedagr8
Bakersfield CA
Best way is to have it flashed with a ford IDS scan tool to fix it. And load load a fresh tune.
Arizona
So going to be having pcm re flashed to stock calibration, then try to load the tune, hopefully this works or ill be in the market for a used one off a wrecked car.
Arizona
Elec Cont Unit (ECU), 4.6L, MT, ID 7R3A-AEC
Elec Cont Unit (ECU), 4.6L, MT, ID 7R3A-ALC
Elec Cont Unit (ECU), 4.6L, MT, ID 7R3A-AUC
Elec Cont Unit (ECU), 4.6L, MT, ID 7R3A-AVB
I just pulled that from a salvage place, these 4 are all listed under a 07 GT with 4.6 and 5speeds, but the ID numbers I have no idea about, what do the letters at the ends of them mean?
lito
Caracas, Venezuela
The engine runs? Does the wrench comes on rather quick?
What PCM code is yours? I can tell what calibration code you need of the list but sincerely you can use any 07-09 auto or manual PCM.
Arizona
Yeah the engine will run, but he told once he gets on it past 4k rpm or so it will limp mode and the wrench light will come on. My tuner was able to get in and start tuning at the beginning and got 12 pulls in and was fine tuning things then the wrench light has come one and we have been having trouble ever since. the pcm id number of my current ecu is 7R3A-ALC. Any other ideas other then to buy a new pcm?
lito
Caracas, Venezuela
I have replaced two 07 pcms, there should be more codes there (2104 is one but is a consecuence of the others) but need a real scanner to read them. One even on a 100% stock car.
Yours is an XZE2, you don't need that specific one, any manual or auto 07-09 will work (The last one I've replaced was an XZE2 and we used an SBM1 one) just need an IDS, read your current and swap the replacement so it will overwritten, then need to re-do PATS.
Arizona
well the results are in folks, got the car back, a new pcm was the issue i guess that stock saleen reflash fucked everything up, but here are the dyno numbers it was hot and im in arizona car was heated by the time it made final pull.
numbers are 424 hp, and 402 tq sorry for the huge image :/
