Turbotungsten
- Joined
- Jan 26, 2008
- Posts
- 144
- Reaction score
- 2
I am finishing my project tomorrow and have a few questions. My old combo was a completely stock 3v with a 60mm single turbo (39 lb injectors), minus axle back and an electric water pump. The new combo is a new aluminum block with a 298 ci Livernois stoker kit, MMR sage 2 heads, MMR custom stage 2 turbo grind cams, CMCV delete, 60 lb injectors, Livernois cam phaser lockouts, and 70 mm turbo.
Here is my question, Can I put in my 39lb injectors, fire this thing up, and drive it nice and easy to make sure all is OK, break in new clutch, and get it to dyno on the old turbo tune, then ill put in 60 lb injectors and build a new tune. Will the car run at all with these mods, and will it run well enough to drive it easy for what I need to do? Now its time for your .02 Thanks!
