Twins anyone??????
RectalRampage
So on a stock internal engine it makes far more sense to make less power using more boost, and more stress on your internals....and in the process have higher IAT's? There is a simple reason why turbo's make more power per lb of boost than any other power adder.
More efficient then nitrous? Doubt it....
hawkeye18
omgwtfbbq
Nitrous can only be used at WOT. Furthermore, bottles off nitrous become hideously expensive over time with regular use. Turbos are in use nearly 100% of the time (except when they're spinning up), and are a one-time expenditure beyond normal maintenance.
I strenuously disagree with your statement.
mmiller40
Nitrous is a compressed gas so that could be somewhat considered "boost".
I think that depends on how they are setup. A simple spray in the intake will not create any more pressure. If it did it would blow back out the front of the CAI.
