fastregalwe2
Need more powa!
Hadn't been with this car in about 3 years. (2008 Saleen S281) Last time out I had 11PSI pulley, Brenspeed tune, Saleen Extreme CAI, 4.10 rear, BMR extreme rear anti roll bar, rear QA1 shocks, BMR adj upper and lower control arms, BMR adj panhard bar, Racestar skinnies and MT ET Street radials w/325 15 tires. On Race tune, 110/93 octane mix and the fat/skinny setup it went 11.83 @ 119mph on 1.8 60'. Fri it had 11psi pulley, Brenspeed tune, JLT 110mm CAI, 57mm TB, Accel coils, 4.10 rear, aluminum one-piece driveshaft, Exedy Stage 3 clutch and Exedy lightweight steel flywheel, Saleen extreme heat exchanger, N2MB WOT box, all stock tires/wheels and suspension on Street tune, 93 octane and street tires it went 12.8 @ 121mph on a 2.2 60' leaving at idle as it kept blowing the tires off. I only got one decent pass without either major wheel spin of missing a gear.
Im thinking with tire and race tune and race gas it should run around a 10.90. Needs a good driver mod as well as I shift like sheet.
I think its time to upgrade to GT500 fuel pump sset up too because on the 121 mph pass I got a CEL for low fuel rail pressure. That was with the BAP at 75%. I turned it up but never got another good pass.
