What will it make on the dyno?
Boaisy
Dark Knight
Memphis, TN
623.96 rwhp / 555.71 rwtq on 3" pulley with headwinds of 2.5 knots (not counting any fans blowing on the motor).
666.027 rwhp / 597.88 rwtq on 2.65" pulley with tailwinds of 5 knots.
BruceH
BBB Big Bore Boss 322
FWIW I did a log today. I selected parameters for dialing in the moving idle and forgot all about returnless fpump dutycycle. However, it appeared to be running out of fuel towards the end of my 7200 rpm redline. There was still enough to keep the a/f safe but it was climbing in a way that is almost a signature for running out of fuel system. I only have 50psi commanded for the GT500 injectors so it might be fixable. Turned the pressure drop up to 58psi for higher pounds of mass.
I think we'll see soon enough. It's pulling hard enough with the 3" pulley that I really don't see a need for the 2.65". If there is enough fuel system left I'll still put it on and see what happens.
jodadejss06gt
TEAM DELETE SHIT
Severn MD
BruceH
You guys are a little crazy imo. The 3" pulley is making 7 pounds of boost. FWIW I'll use the SAE corrected numbers. Pretty sure it's not going to have enough injector for the 2.65. The pull has to reach 7k rpm to count.
JoshK
Modder AKA Fuel
Nebraska
Are you still running the same fuel system that supported the 699 on E85 before Bruce?
BruceH
Almost. Different injectors. The new GT500 58lb? at 3 bar. A while back I calculated them maxed out at 76lbs iirc. That was with 4 or 5 bar, can't remember. Just pumped the psi up to 58psi.
The 970cc Bosch Racing injectors that were used with the procharger were only at 39.15psi.
Department Of Boost
Alpha Geek
As long as you don't run out of fuel I think I'm looking pretty good.:thumb2:
BruceH
569/509 SAE corrected. 585/523 STD and Uncorrected. SAE total is 1079.12. Hammeron guessed the closest.
It didn't run out of fuel but I didn't put the smaller pulley on. I'm sorry but arthritis pain almost had me canceling the appointment all together. Pulley swap just didn't happen.
It looks like this little blower is most efficient up to 6k and then it drops off. I'm thinking it has something to do with my combo of bore, stroke, and total displacement along with the ported heads and blower cams.
Comparing uncorrected numbers with uncorrected n/a numbers it picked up 150/137rwhp/tq with an observed 8psi. Not bad at all considering the cost and low boost. IIRC I have a total of under $3k invested. I really like the power level. Many times I've stated that around 550 is where the fun starts to fall off on the street with this car.
Does anyone know what a GT500 with the M122 makes at 8psi? It probably isn't that low of boost from the factory. My displacement is only about 8 cubic inches less.
I'll probably put the smaller pulley on at some point just to do it. Or, more likely I'll purchase a 2.3 tvs during a moment of insanity.
Here's the dyno sheet. I'll post up the corresponding datalog shortly.
Edit: Here is the datalog. The values are at 7072 rpm.
