what will it make?
mustangflanagan
south jersey
Change the cams and headers...you should make 550. I have a set of Detroit rockers that I took out of the car and replaced with the stage 3 blower cams. Made a little more power....
Pulley that thing down a bit to 14 psi and you will make some more power as well..
What pipe set up are you using? The HO kit or the standard kit? That might me restricting your numbers as well....
I. Upgraded to stage 2 pyping and intercooler
BruceH
BBB Big Bore Boss 322
Any insight on why
Same dyno, same weather correction, same tuner? It would be interesting to see what would happen by just going back to the stock manifold. Torque would go up imo.
Be careful with the Kooks cats. Greg lost a motor when one came apart.
mustangflanagan
south jersey
Its 60 degrees here lol lasy dyno had dif correction factor. Std before was 497 and 460 tq now 540 and 480 tq. Ps only using cats till after inspection the sae was 525
