Depends. What exactly is it that you're doing with your car, and what are you trying to improve?
. I believe that might be due to either fluid/line heat, or rotor heat, not sure.If you step on the pedal, and it feels like a wet sponge, then you boiled the fluid, and the gas is allowing compression. Swap the fluid for higher-temp stuff, like Castrol SRX ($$$$$$) or Motul RBF600 ($$).
If you step on the pedal, and it's nice and firm, but the car just doesn't want to slow down, and you keep stepping on it harder and harder, with little additional braking effect, then it's pad fade.
Any way you cut it, if you're going to put the car out on a road course, your brakes WILL get a workout. My advice would be to start with fresh rotors front and rear (newtakeoff.com or rockauto.com), and a good set of "semi-race" pads, like Carbotech XP10 or Hawk HT-10 up front, and XP8 or Hawk HPS in the rear. Flush the system with good fluid, and then just go out and drive...
Keep your stock stuff, and swap back after the track event. The race stuff is noisy and dusty, but it will survive the (ab)use you're about to put it through.
+1 on the rollbar, but unless you REALLY want it, skip the k-member and the limiters. The stock stuff is plenty strong enough!
SS lines and brake ducts are awesome, once you get your braking figured out. They'll help get that last bit of pedal firmness, and keep your brakes cooler, longer. If you become a track-whore, like me, then upgrade to the BBK as soon as you can afford it. The pads and rotors will last sooo much longer.
Drilled/slotted is pure bling, and actually detrimental to track braking, as it removes mass from the rotor, effectively making it a smaller heat sink. The drill points also create stress risers that are VERY prone to cracking under thermal cycling.
Good call on the rollbar, particularly with a convertible, but I would skip the k-member for now, and put that money into more track time. The stock stuff is plenty strong enough, and you'll get much more benefit from the additional time on track than you will ANY bit of kit.
You always put up the best information imo. I completely agree with all things said. The brake ducts I made last week. I won't hook the hose up till I put the front end back on.
I'm going to repeat this, as it's huge... DO NOT get drilled/slotted rotors (maybe slotted if it's an expensive track rotor, but NOT drilled)
+1 I serverely cracked my BAER drilled and slotted rotors in 2 track events. I was lucky to have an unrelated mechanical problem during the 2nd track event(3rd total track days) or it would have been catastrophic for me. BAER makes a slotted only rotor which I have run for several track events w/o issue.
