No offense, but no, I will not put any UPR parts on my Mustang.
Hey Kelly, got any facts to back that up, or just hearsay.![]()
Don's Stang, we fought and fought people for many years about our design for our Panhard Bar. It was said to be a bad design, and that it is weak.
Out of 11,661 sold since 01/01/2005, we have had less than 5 reports of failure.
I am glad to hear they are holding up. Though a bar with adjustments at each end it has to be stronger. I like your products, just not the Panhard bar. Maybe I am a little old school, and am also a off roader where a bar like that wouldn't hold up. So when I went with a Panhard bar on my mustang, I went with one with adjustments on the ends. I just know if I put one on with your design I would always worry about it. Which is why it is a no no for me, and I am sure I am not the only one who thinks like that
I had a UPR camber plate fail and send a strut through my hoodWow why so against UPR?? I am not bashing you, as most of the parts you have were awesome choices, but don't understand your comment about why you wouldn't ever put a UPR product on your car, or even consider one of there products
I see you have a bunch of BMR lower arms already, so I say go with there upper, and have a matched rear setup
I like most of BMR products, they are well made, and well engineered. Though there Panhard Bar which looks like you have, is one product I question the design. Having the adjustment in the middle of the bar is a no no to me. While might make adjusting easier, you now have a weak spot in the middle of the bar.
To me the UPR Panhard Bar is a stronger design, yes might be a little bit more of a pain to adjust, but how often do you adjust a panhard bar
Never again.
Right now, IF I do an aftermarket UCA, I'm considering ones like the Steeda since I wouldn't have to (or want to) install a new bracket/mount also, and having a DSS driveshaft I keep reading that adjusting the pinion angle is not needed
Gabe, can you calrify? I don't quite understand what you are referring to about the mount comment?
Skwerl, that arm won't work on 11+ cars bud.
