Whipple 2.3 Complete Intercooled Kit ***SOLD***
Status
Not open for further replies.
Stang 23
Chatsworth, CA
For sale I have a Whipple 2.3 Complete Intercooled Kit. It has the 07-10 style crossover but can also be used on 05-06 all you would need is a different upper radiator hose. The kit has about 1,500 miles on it. I basically freshened up the kit. Repainted the metal air box and a few other pieces and cleaned up the plugs etc. This kit practically looks brand new. It includes everything including a brand new Saleen Extreme heat exchanger with dual fans, new serpentine belt, new dual fuel pump and low mileage 39lb fuel injectors. The fuel pump was originally purchased from Jeremy at S&H Performance. It’s a modified GT hat with dual pumps. Each pump flows about 235 lph each so about 470 lph total. They will support up to about 650rwhp with 60lb injectors and close to 700hp with 80lb injectors on pump gas. This is a custom setup that actually flows a bit better than the regular gt500 fuel pump. It has larger fuel hose, 10 gauge wiring throughout and a larger Y fitting joining the pump outputs together versus the T fitting that is used on the oem gt500 fuel pump. The fuel hat is a direct swap plug and play with level sender and the wire kits come with heat shrink and zipties for a clean and complete install. This kit also uses the stock FPDM and does not need a second FPDM as it will run just fine off of one FPDM. Looking to sell as a kit right now. I realize the date is off I didn’t have time to post this ad until today. Asking $3,700 plus shipping and fees. I’m located in Chatsworth, CA. If you have any questions about the kit feel free to pm me.
DRock
What is going on here?!?!?!? good luck with the sale man! Good guy here people!
members are allowed to make offers, there is no rule against it, there are rules against all the other BS posts that have been cleaned up.
if a seller doesn't want to accept an offer - he can counter or decline the offer.
stop fucking up the treads with nonsense...
Status
