Whipple GT500 Mono blade throttle body
JimIII@JDM
Yes it does require a tune, both for your wide open throttle air fuel and the idle settings. The bigger, single bore causes more airflow which results in a leaner air/fuel mixture. Also the larger opening draws in a ton more air at idle and can make your idle RPM erratic until the car is recalibrated. Overall its a big power gain for most cars. Contact me if your interested at 732-780-0770
JimIII@JDM
i have a bone stock 12 gt500 will this work also how will this help with a 2.6 pulley can tune. a lot of difference or just a little after these mods
You would probably gaina bout 20-30 RWHP on a car like yours! its a huge gain, it does require tuning like I mentioned in my last post
