Synyster06Gates
Looks great. Glad to read a good report on these. Also good to hear about the Pypes X piece fitting in there since I have an ORH from them. Would you say that the motor mounts are necessary for install or just something you'll want down soon after?
Well, with these you get 2 offroad H pipes. One that is your typical straight pipes. The other (the one I'm using) will pass visual inspection because it has resonators.
I did the Prothane motor mounts with the headers. I wouldn't say they're NECESSARY, but they definitely raised the engine a bit. You could probably shim the stock washers if you didn't want to replace them. They make the car shake a little more with the cams. It's fun. Also fix sloppy 1-2 shift.
That looks awesome man. Damn you though, I want headers again...
For $500 there's really not much more you could ask for. I'm happy with the purchase. I like that they are full length LTs.
