Window switch
Bodvar
Ok so this is an unexciting thread. My window doesn't do the thing where it goes up on its own when you pull the switch all the way up anymore. And when I open the door, it does the thing where it goes down a little bit but it doesn't go back up to reseal the door. The latter is the biggest problem because I don't want any water to get in. Is this just a bad switch?
AndrewNagle
Mountains of NC
turn key to accessory hold switch down for 3 seconds, hold switch up for 3 seconds....something like this
it's in the manual, either use the one you have or google it and view online
Window not going up when door is closed, was my first indicator my battery was dying. (And needed to reset the window as mentioned above)
