Okay, I'm getting pissed, been trying to fix for 2 weeks now. Got a new clutch (Mach 350 stage 1 with hydraulic TOB) did the whole clutch install correct. Bench bled the clutch the clutch is great in feeling. For some reason it doesn't disengage. I try to put it in any gear and it won't (with the car on) but with the car off it goes right in, I start it up and it goes without me even touching the gas. What do I have to check because I even sent back the clutch and got a brand new one and same problem. What should I check if it's not my slave or TOB? Need help asap!!
