The tag is on the '06 one; per the 5R3T, that should be '05/06.
Let me go look closer at them.
Lol, so I put the two harnesses side by side, comparing the connectors and wire colors.
They are the same, except:
- the power connector on the '07 harness is rectangular while the '06 one is more square (trill-gear-head had issues with that connector)
- there is an extra connector on the '06 harness for the oil temp sensor (deleted in '07)
- the 1 connector to the fuse/power block has a couple extra wires in it on the '06 and a couple in different places; but this connector looks like it would be very easy to remove wires and reposition them, very easy.
- the 2 connectors to the ecu are also easy to take apart to get to the pins, and it looks like they can be removed without too much effort, and relocated to where needed.
But where the connectors connect to, they all look the same (or close to the same) colors and all on the connectors.
But I found out as a result of comparing these 2, that the '07 harness is in much better shape than the '06 harness: the '06 harness is missing 4 connectors for the auto tranny!!! Dammit! Looks like they were simply cut off. One of them is there, but not the 3 small ones and the one big one. (I wouldn't have noticed this until putting it together, so thanks! I can steal them from my stock '05 V6 harness if I need to.)
And yes, no part number tag on the '07 harness.
