This is the second HTO plug that has broken in the same manner. The ceramic around the center electrode has broken and fallen to the grounding bar causing a misfire. The first one was on cylinder #6, this one was cylinder #4. Anyone know what can cause this? In both cases it happened at WOT in 4th. Neither time was high RPM, both times it was about 4500 when I felt it stumble. Engine is a 302 stroker with a Hellion pushing 11 psi, 60# injectors. It makes ~550/520 at the wheels.
Sorry for the crappy pic, took it with my cell.
