Weld Racing Prostars????
Born To Run
Woodstock,Ontario
I would like to put a pair of Weld Prostar 15x3.5 rims on the front & 15x10 on the rears.
Are there any fitment issues?? Will i need spacers,studs,relocation brackets etc.
I don't care if the wheel sticks out a bit either.
Any input would be welcome.
Hawgman
THE fucking bad guy
Not sure on the Prostars, but there have been several threads here on the Racelites not fitting
don_w
Dyno Numbers - Who Cares?
San Diego, CA
The fronts can be done... I ran 15x3.5 draglites for a long time. It took 3" studs and 11/16" spacers for mine to fit. But, the rears may be a much bigger problem.
94tbird
4R70W FTMFW
I think he is talking about the new Greg Weld Rims Don, not the original weld or weld xp's. If he is, no the fronts will not fit a GT without major modification to the caliper and spacers. they will fit a v6.
don_w
San Diego, CA
"Pro Star" is a Weld term... I thought the Greg Weld's were called Dragstar.
thump_rrr
Montreal Qc,
My friend is running 15x3.5" Prostars in the front along with what I believe to be 11/16" spacers and longer wheel studs.
For the rears He is running the 16" prostars.
Born To Run
Woodstock,Ontario
Rims
Has anyone tried the 15x10 prostars(Weld Racing) on the rear.
I realize the 15x3.5 on the front require a spacer & longer wheel studs.
On Greg Weld i called & talked to Mike today & he assured me i could order the 15x10 Greg Weld rims for the rear without fitment issues & the front skinnies may require a 1/32" off the calipers if any.He said some need a grind & some don't.
I was told to order them through Sumitt.
I am doing my home work on this project,so i am calling on everybody taking names & numbers if issues pop up.
PNR Welding
Hammonton, NJ
I am defintaley interested in getting the rears to fit. I have the Bogarts on the rears now and I really dont trust them. I am going to go to my friends house when I get my car back and put his on and see what it will take to get them to fit. Ill let you know next week.
thump_rrr
Montreal Qc,
Is it on the street or the track that you don't trust the Bogarts?
If you want to sell your rear Bogarts let me know.
PNR Welding
Hammonton, NJ
Ill let you know. Once I find a way to get the rear welds to work ill put them up for sale.
I dont trust the Bogarts on the street. The rears been holding up fine but the fronts dont hold up at all. Im sending my one front to get fixed and will be selling the set.
biz4765
Ridley PA
I am also very interested in having Prostars all the way around on my car...please do keep us up to date with your findings!
94tbird
4R70W FTMFW
Im selling the greg weld Drag wheels for the rear 15x10 for $250 for both
SlvrS197
Do the rear greg weld wheels fit with no problems? What size are they?
Born To Run
Woodstock,Ontario
Rims
I am considering the Greg Weld wheels as they are much cheaper & don't have serious fitment issues.
On the rear i am prepared to remove the swaybar anyway.
The fronts are no problem,spacer & grind a little.
Why are you selling them?? What are you replacing them with??
Did they fit on the stock studs??
Will you include the nuts & washers??
QMSolutions
Houston
I know this thread is old but, you can get the 15x10 prostars to fit with about $35 and a couple hours of time.
