Race Seat and Harness Mounting
Port Coquitlam, British Columbia
For those you with racing seats, what did you guys use as a mounting solution?
I recently bought a OMP WRC racing seat, with side mount brackets. I believe that the Sparco floor bracket will work, but here's the thing: I have a track day on the 27th, and shipping to Canada is slow as all hell. What should I do? Modify the factory power seat bracket? Get someone to weld a custom bracket on the floor?
Once that is done, I will mount a 6pt harness. I understand that I can wrap the shoulder belts around the harness bar section of the roll bar, but where do I tie the shoulder and anti-submarine belts in?
Thanks guys.
DusterRT
Defected to Deutsche
Seattle, the Sunshine City
Try Speedware Motorsports for the floor bracket. Here's the link to the Mustang brackethttp://www.speedwaremotorsports.com...ng-brackets/speedware-ford-mustang-05-bracket
If those are the Planted brand brackets, they are pretty nice pieces. If they have them in stock and can't get them to you on time, maybe I could meet you at the border with them or something.
I have my 4-point lap belts at the factory mounting points. For the anti-sub belt, I'd refer to the manufacturer's installation guidelines..for getting the geometry and routing taken care of. Here's Schroth's for example: http://www.schrothracing.com/sdocs/2009_Competition_Instructions.pdf
pcdrj
Bucks County, PA
There's a reinforced area that runs behind the seats. You can slip in a nut and a thick washer into the slot to hold the bolt.
Philostang
Chrome Hater
Chicago
I fabbed up my own bolt-in brackets. They're MUCH beefier than anything I've seen in the aftermarket, but I paid about a 4 lb weight penalty for each of them compared to the bent-bar style designs.
If I had to do it again, I'd use a slightly different design but I'd still use tube stock over the bent-bar approach.
I think Steve Poe once posted a nice pic of his brackets, so he might share again. If I recall, it was very similar to the FR500S units, including being fully welded in (something I didn't want).
Best,
-j
Interesting, thanks for the pictures you guys.
PCDRJ, did you mount both anti-submarine belts to the same point? And I suppose you mounted the right side lap belt to where the seat belt buckle would originally bolt in? I see that you used the original bolting location on the left side. Having equal length mounting points doesn't matter because you can always adjust the straps, right?
pcdrj
Bucks County, PA
Mine is a 5 point so only one anti-sub... if you mean both sides, then yes they are the same. I drilled holes in the center tunnel for inside location and installed large washers underneath. I had to position them up a little to avoid e-brake hardware. It's best to have equal lengths but not always possible.
Philostang
Chrome Hater
Chicago
Just as a safety heads up, these are not "just" large washers, etc. The eyebolts in these kits are forged, not bent, and the washers are at least 1/8" thick. Don't cheap out and get something from the local hardware store.
If you're going with square or rectangular plates on the bottom, be sure to round the corners off with a good radius. Sharp corners can act as a shear and cut right through thin sheet metal. You want forces evenly distributed across a large area.
Pegasus Racing and many other race shops carry similar kits. Heck, hit up Sam, he might have them as well (I got my harnesses from him - he carries A LOT more than what's on his site), and just about everybody sells them in the same price range.
Best,
-j
Understood, cars can be replaced, my body can't, so I don't plan on cheaping out for proper safety equipment.
I have now gotten word that for my local timed events, starting in the 2012 season, a HANS type device will be mandatory. Do they require a special type of shoulder harness?
