BoostedGt480's Build Thread
iRoush
Roush God
Fort Lauderdale, FL
All nighters are fun! But not with work the next day. I went to the track the next day. haha!! Kudos to you man! And yea, do it while you're single. Most women don't get it. Unless she's a car girl. Then that means you gotta share the funds for her car. That's no fun. haha!
Surfstang2020
Myrtle Beach South Carolina
He speaks the truth lol most girls I've dated don't get why I pay so much for parts for the mustang though I am currently talking to a car girl she drives a car from brand x aka the dark side Aka chevy lol trying to get her to switch over I don't know if I could pull an all nighter but you seem psyched to get it done so sweet !
Sent from your moms phone
BoostedGT480
Slow 3v
Montgomery, AL
Im somewhat of a youngen...24, but have tons of white hair...damn genes! lol
Uploading pics now. I took just took off work. Couldnt handle it anymore.
bmaxwell
BÆST
ATX
Hey at least you're not going bald already lol I am almost 24 and already just about fuckin bald but oh well at least I'm not a bitch. And nice work bro that thing is looking very nice!
calispecial08
dang mann! coming together nicely wish i could afford to do something like this right now...
BoostedGT480
Slow 3v
Montgomery, AL
well im loosing hair too..lol Right in the corners of my head. what is it called - widows peak?
bmaxwell
BÆST
ATX
I think a widow's peak is like that little sharp point of hair right in the middle of the forehead like vampires have lol. Anyways yea it sucks
BoostedGT480
Slow 3v
Montgomery, AL
Been working on it since I got home. Had to go to lowe's and get hoses for the heat exchanger and everything...
Here are the updates:
- Installed driveshaft
- Installed BMR driveshaft loop (had to be modified to fit my 4" driveshaft because car is lowered. Driveshaft was hitting loop)
- Hooked up wires on alternator
- Hooked up all coolant lines
- Run lines to breather can
- Hooked up oil pressure connection and modified stock inlet to fit in connection for my AEM oil pressure line
- zip tied all loose lines near headers/exhaust
- tightened all fuel rail connections and lines
- checked all grounds and gave the car one last inspection
- took it off the jacks and rolled it into the garage
What needs to be done:
- put clamps on all coolant hoses
- run lines for oil relocation kit
- install intake and accessories
- install battery
- solder BAP wiring connections
- zip tie all loose wires in driver side footwell
- install 8 rib belt
- tighten sc belt
- find bolts and tighten fuel pressure regulator
- install trunk liner and plastic rear liner
- install bumper and lights
- bleed clutch
OH, and to top it off, I got to remove the KB, alt, fuel lines, rails, and manifold. Do you know why? Because Im STUUUUPID! I forgot to hook up the connection in the valley of the block. So, hopefully tomorrow I will be done. It seems like a lot of crap, but most of this is small stuff so hopefully I will start it up tomorrow or Friday. Just worrying myself to death that Im forgetting something so I'm re re re re re rechecking everything
tmcolegr
It's All About the Build
Central, FL
I noticed your block does not have knock sensors. I have to assume you already have an updated startup tune...
BoostedGT480
Slow 3v
Montgomery, AL
Disappointing night...I didnt get to start it. Spend a lot of time taking off the manifold and KB to plug in the connector in the valley. The 2.6's require you to put rtv silicone around the base so I caught hell scrapping it all off and getting a smooth surface again. So that took alot of time.
Then I routed all my hosed for the supercharger/heat exchanger/sc coolant tank.
Then I had to route all my hoses for my oil relocation kit and breather can.
Then had fun installing my intake with all the new hoses in the front bumper area where the filter is located.
The went to O'Reilys and got a new Red top battery, coolant, water wetter, oil, filter, and random clamps I needed to clamp stuff down.
So with ALL that being said, this is all thats left:
1) Solder BAP wiring
2) Install trunk panels and floor board
3) clean up the wires in driver foot area
4) bleed the clutch/slave
psfracer
billy badass
Valencia, CA
So it will be running for sure for the weekend. You are very close now, just take your time and do everything right.
BoostedGT480
Slow 3v
Montgomery, AL
Yea, hopefully tomorrow evening when I get off work. The longest part is going to be soldering the wires and that doesnt take that long..
Trying to figure out exactly how to bleed the clutch. I heard to just lift the driver side up and pump the clutch. But Im not sure how that works
bmaxwell
BÆST
ATX
Yep just jack it up on the driver's side and get all the bubbles out. You'll see them coming outta the brake fluid reservoir I believe, and also just pump until the clutch feels solid and normal.
BoostedGT480
Slow 3v
Montgomery, AL
She's running!!!!!
and I already had an angry neighbor come storming up the street telling me to cut it off. Said "You have been doing this for the past couple of months"...ahahaha I said, I think your mistaken, this is the first time I have cranked it in almost 6 months...I apologized and continued to back it into the garage...
bmaxwell
BÆST
ATX
Congrats!!!! And that neighbor needs to fuck off he doesn't know what it's like obviously
