suggest cutting the oil filter open (carefully) and see what type/how much foreign debris made it to the filter
they have a tool for that?thats the next step this weekend. I have an oil filter cutting tool.
Fuck, I grew up knowing that tool as a "hacksaw"
any other new info?
any other new info?
They sure do. Most other methods of cutting an oil filter open, result in introducing too many contaminates into the filter. When your done cutting the filter open, you have no idea what you're looking at - debris in the oil filter or contaminates you just introduced cutting the filter open. Not to mention using anything other than a filter cutter usually results in unnecessary lacerations to your hands & fingers.
messier than a post-op thai hooker
at least its the right tool for the right job. good luck this weekend.
whats the plan after the filter?
Get the tranny out of there?
Cant remove the tranny, as the converter is bolted to the flexplate. The only way i see removal is to literally pull the engine and converter together. it sounds dangerous
How will you separate them out of the car? If the motor won't turn, doesn't that mean your can't turn the torque converter to hit all the bolts?
