Flaming rivers rack with bmr k member
matt06
St. Louis
Trying to install a flaming rivers manual rack with a bmr k memeber and wondered what people have done as far as bolt? New rack didnt come with new bolts and the stock bolts are not long enough plus the nut is welded to the stock k member. Figured i could just go to lowes and get a bolt the same grade and size, just longer with a nut that fits but thought id ask everyones advice. For the price id have thought flaming rivers could have spent a few bucks and included new bolts and nuts but maybe the stock ones work with the stock k.
thanks, matt
06silverbullet
orange county, ca
thanks, matt
maybe it was supposed to and they happened to make a mistake, also you treid calling them and asking them for the thread specs on the nut on the k member to that you can make sure it threads properly
MIKE93SVT
Savior of Junk
Hawaii
i've always just got some grade 8 bolts and locking nuts. good to go for a couple bucks and an excuse to shop at lowes
rayS197
virginia beach, virginia
on the stock K-member and the steering rack, are you talking about the two 18mm nuts and bolts at the top of the rack that hold the rack in place?
matt06
St. Louis
im at lowes a few times a day picking up stuff for the apartment building im rehabing, dont really need an excuse to shop there but prob what ill do lol
matt06
St. Louis
yes, those are the 2 im talking about, theryre not long enough to fix through the rack and the bmr mounts, plus the nuts welded to the stock k...
rayS197
Hmm, They should not be welded. My 06 and Gregs 2010 were not welded when we did the K-members. They are just freaking tight as hell and a PIA to remove. Get you some longer grade 8 bolts and washers.
matt06
St. Louis
seemed to be tach welded, i took the bolts off before i realized they werent long enough cause im swapping both at the same time. nuts were def still attached to the k member. ill check later, maybe theyre not welded but didnt come off with the bolts out. and cars an 06 also
matt06
St. Louis
heres a few pictures, dont show the rack in the car as i didnt have time to run to lowes this afternoon but will monday and will get it bolted up then.
matt06
St. Louis
yeah, it seems like a very well built piece. Pretty sure i could use an intervention myself, oh well
psfracer
billy badass
Valencia, CA
Here is a picture of mine (when I had the mod motor). I went with some Grade 8 bolts/washers/nuts.
matt06
St. Louis
thanks for posting the picture, thats what ill do. everyones red k members makes me wish id repainted mine before throwing it on
matt06
St. Louis
Also, what outer tie rod ends did you use? for some reason when i ordered it i was thinking it would come with them, apparently misread jpc's site
