Detailing Questions-Answered
Seer
Hey Seer, you mention/recommend Opti-guard quite often and either my searching is terrible or it has a slightly different product name. Any links/details are appreciated.
Opti-guard is the professional version of Opti-coat.
cwhit23
What do you recommend for cleaning cloth seats. Here's the deal. My wife's car has dark gray/ black cloth seats, they keep lint and pet hair on them all the time. A vacuum doesn't even come close to getting it off. I have tried lint brushes and tape but nothing seems to get them cleaned up.
Edit: and while I'm thinking about it, I've seen finsihing pads in red, blue and gray for the porter cable. Which is it? lol this gets confusing, if you go with meguirs it's one color, wolfgang another color, etc.. are these all okay for applying sealant or wax? I want to buff the car, then seal it, then wax it.
Seer
they actually make a carpet and linen attachment pad for the porter cable ita a brushed pad. Grey pads are a little more course but are not abrasive use them with glazes finishing polishes or light cut. Blue is for applying sealants, red is for liquid carnauba. Gold is basically the same. You truly just need orange, white and grey. Green pads are nice to have too. So compound, polish, and finishing. (green is light polishing if going by LC standard).
Not all pad systems are the same but their descriptions are standard.
cwhit23
I was looking at the wolfgang kit.
http://www.autogeek.net/wolfgang-porter-cable-swirl-remover.html
It comes with free red pads as well. Would you rate this better than the Meguairs kit?
I'm going to look into the uphosltry brushes then and see if there's anything there that can be combined with a cleaner. etc. Thanks alot for your help on everything I've been asking lately. You've educated me alot!
I also just noticed they have a menzerna kit as well..
Seer
my opinion is menzerna works better on the hard clear coat the 2010+ mustang has. Those red pads in that kit are for hand application of wax and sealants. They are imo one of the best hand pads out there.
cwhit23
The menzerna kit is cheaper too. I plan on buffing , sealing, then waxing. I hope it turns out looking good. Thanks for your help!
erat
I have a couple questions about AQuartz:
My car is just painted, cut and buffed and buffed and buffed. So, I figure this is as perfect as its ever going to be.
(1) Do I need to remove any polish left behind from the polishing process before applying, even if they skip any waxes after the compound?
(2) Aquarz's site says it needs two (2) coats of TI and Premium on first application, doesn't say how much the bottles will cover. Will those little bottles cover the entire car, twice? Is twice necessary on a newly cut car?
Seer
car had to be bare. You should get about 2.5 coats oer bottle.
cwhit23
Okay, So I've about got everything ready to go. I think I've decided to go with the megs 105 and 205. I plan on using this for my truck it has alot of scratches along the bed area and water spot etching on the hood. Will this work?, also reading through this thread about how abrasive the compound is I'm kind of scared now. lol
Seer
You're using a PC right? You won't burn through the clear.
Start with your least agressive combo then work your way up. If there are actual swirls present then most likely, you will just need to go right to your compound and orange pad, then pass over again with your polish or finishing pad and your finishing polish.
Megs 105 and 205 are a good combo, I don't use it though due to how badly it dusts.
cwhit23
Yeah, I'm using th PC.
I haven't bought anything yet, was just looking at it since i'm familiar with it. I know you've suggested the menzerna, but it seems more aggressive than the meguiars. as far as how far it cuts. (if I'm reading things right.)
stupid question, it has factory 4x4 stickers on it, will this affect those?
Seer
Menzerna SIP and Megs 105 are about the same as far as cut goes.
Here is a menzerna chart
http://www.autogeek.net/menzerna-of-germany.html
cwhit23
Thanks Seer, I'm new to this, but always enjoyed detailing cars and decided to take it to the next level of things as a hobby, this thread and you have been a great help.
LindsayEOD
Hey guys. I've read through this section and have only seen foam guns mentioned a few times. I am wanting to purchase one and would like to see if anyone recommends a specific brand and size. Thanks for the help.
cwhit23
Did you like it?
Yes, I liked it. I only got to use it a couple times before winter hit but it seemed to work pretty good.
NastyStang or Seer may recommend something better, but I was happy with this one.
LindsayEOD
I appreciate it man. There are only a couple that I can find, but I dont want to purchase one that doesnt work well.
Seer
the basic gilmour foam gun is more than sufficient, unless youre attaching it to a power washer.
LindsayEOD
I am just going to be using my garden hose. Do you just use the CG Maxi Suds II? Thanks man.
