On Menu: Heads, Cams, and a side of NO2
08StangGT_CS
San Antonio, TX
I'm about to start a fairly mild build and wanted to see your thoughts/opinions/criticism/etc.
Car: 2012 Mustang GT 300A 6M 3.73s
Current Mods:
JLT CAI & Catch Can on Pass. Side
BBR 91 Oct Tune
ARH 1 7/8" LTs with catted X Pipe
Flowmaster Hushpower
Somewhere in UPS: MGW Shifter
The plan:
I bought a set of Stage 3 Comp Cam NSR NA cams with limiters. I also have a set of heads on the way to Livernois to get CNC'ed. I was going to do Livernois Springs but would the Boss Springs be enough/ a better choice? For reassembly I was thinking or purchasing the Ford Racing Boss 302R Cylinder Head Change Kit M-6067-M50BR.
Currently sitting all over my living room is a Nitrous Outlet Hardline Kit, NO purge kit, NO Blow off tube, Nitrous Express Dual Stage Progressive Controller, and Nano 4500 Nitrous Assist system. Still want to buy a fuel pressure cutoff switch, the NHRA blow off valve, and an electronic pressure gauge. Still undecided as to how big of a shot I want (75?....100?). Any suggestions?
I'm looking into purchasing a set of 47 lb FRPP EV6 injectors. Would these be enough? Will I need any other upgrades to the fuel system such as KB BAP?
I've thought about adding a throttle body to the mix. The thought of the Boss intake manifold has also crossed my mind. Thoughts on either one of these?
I still have no idea what I'm going to do as far as tuning.
I will do suspension/ tires a bit down the road.
It'll be a weekend car with track visits at least once a month or more if time permits.
What do you all think?
BlackMamba03
Iowa
There is hardly any difference between the GT and Boss springs. You should go with the Livernois springs. Also, if you're going with a nitrous kit then you'll need colder spark plugs. As for throttle bodies, there are a few good choices. I'd install the Boss manifold also. I'd look at Jon Lund or stick with BBR for tuning.
nenegt
Laredo,Tx
You gonna have to post a video of that beast. We wanna hear that exhaust.
JEWC_Motorsports
S197 Junkie
I will let you know how his car is doing, my brother seems to have moved to Mexico....
08StangGT_CS
San Antonio, TX
Almost.
08StangGT_CS
San Antonio, TX
