Mattr89
Cars>Woman
I just installed a pair of Upper and Adjustable Lower Control Arms from BMR. I got the pair for 60 bucks. I couldnt resist! I am going to get relocation brackets soon.
Well i used the stock mount for the upper, i reused both factory bolts on the top, one goes through the back of the UCA and the other goes through the mount on the top of the axle housing and through the forks of the UCA.
Then i installed the LCA's, they are the red poly bushings on one end, and then adjustable on the other(see pic below). Can this be pinion angle? From the pic below, i installed the red bushings on the frame side, and the adjustable end on the axle side. is this correct?
http://www.bmrsuspension.com/siteart...A021_large.jpg
It doesnt seem that there is an offset, the axle side of the LCA's are even spaced with no offset. I installed them, they were set up to the same length at the stock ones, may be slightly off.
i tightened everything down and now when i shift from 1st to 2nd, or 2nd to 3rd it clunks.
Like when i push the clutch in, and then shift and let off quick it makes a noise the seems to be coming from under the center console.
any help would be greatly appreciated!
