Nastystang06
Pinion angle has no effect on gear whine.
I didnt know it was actual gear whine, thought it sounded LIKE gear whine.
I wouldnt know I have never had issues, it was just a thought
The UCA bolt is typically an issue if you use the stock Upper Mount with an aftermarket UCA; and retain the factory sized bolt. The factory hole in the upper is larger than optimal, and the rigid aftermarket upper will cause noises to become present.
When you install an aftermarket Upper Arm, you will want to install an aftermarket Upper Mount. There are also "anti-clunk" spacers available for this, but I always recommend an actual mount to cure the issue.
Here is the issue 9 times out of 10 when my customers call with a "clunk" issue:
As you can see, the factory upper mount has a large tolerance. Add to that tolerance issue, an aftermarket upper arm that is 200% more rigid....and you develop a clunk that is very irritating.
If someone is experiencing a clunk with our upper arm and upper mount installed...I typically recommend them to check their torque settings, and inspect their bushings.
OP, I think you have the very first versions of our parts. My guess would be that they are very used/worn... Bushing issues and/or sleeve wear may be your issue.
my last concern is, i just got my pinion angle at -3 i believe.... i used the analog gauge and the pinion flange ready 2 degrees to the left of the zero, the driveshaft read 1 degree to the right, that means -3 degrees pinion right?
-2 + (-1) = -3
I have 2 questions, if i add relocation brackets from BMR next week or the week after and i bolt my LCA's to the middle or bottom hole on the brackets will i have to adjust my pinion angle again?
You will not have to re-adjust pinion angle.
Also i dont believe my LCA's are completely equal length, i believe they are slightly off. what is the negatives of this? Is it a big deal?
Yes it is a big deal. Negatives are too long to list. Just make them equal.
...I had the rear tires on "ramps" suspension fully loaded...
Rear tires on ramps, front tires on ground?
I'm in the process of redoing my rear suspension components, and I'm getting ready to dial-in my pinion angle. With the car on the ground I marked the rear shocks using painters tape, I then put the rear on ramps and checked the tape, it was not at the same point as when it was on the ground. I think you need to have the front and rear up on stands to have the suspension properly loaded.
May not make much of a difference, but I admit I don't know what I don't know...
if i cant fix this issue, or find the clunking, these are the parts i plan to use.
http://www.americanmuscle.com/adj-upper-control-arms-jnm2005.html
http://www.americanmuscle.com/2005-powdercoated-rear-trailing-arms.html
are these good parts?
The only thing i dont like about an udjustable UCA is it has to be unbolted from the AXLE housing in order to lengthen.
There's only so many moving parts back there. With a little patience you can check all of them and find the clunk. I have noises appear once in a while and keep looking until I find them.
(driveshaft reading) - (pinion reading) = pinion angle with 2-pc driveshaft
(-2.5deg) - (-4deg) = +1.5deg
Again, just asking for clarification as I'm getting ready to adjust mine, and this makes my head hurt...
