05stroker
Never enough power guy!
I am relocating my AIT sensor to run meth. After some pulls this weekend I am seeing 178* AITs. I an running a F1a with a 24 psi pulley and a wastegate with a 16 psi spring for the street. After talking to Lito we decided meth was the way to go. On his recommendations I started looking into the AEM 30-3000. I liked the info I found on it and have it on the way. I also purchased a AIT sensor from a 99' Lighting (DY-1159 9C1Z-12A697-B) and a pig tale (WPT-322 3W2Z-14S411-JZA0 ).
I will be running this setup connected to my AEM Trueboost (30-4350). Lito suggested looking into a way to connect the meth kit to the true boost so it would pull the boost if the meth runs meth kit runs low on fluid or there is an issue with it. I then called AEM tech support today and found that if I connect the green wire (Safe Boost) on the meth kit to the orange wire (Scramble Boost) on the Trueboost and set the desired boost level it will shut the boost down to what ever boost I program the Trueboost for.
Now the question is, where do I mount the new AIT sensor?
There are a few spots on the JPC intake that I am looking at. One is on the drivers side front of the intake and will screw right in, the other is at the drivers side rear and will need to be taped, and the final location is in a port under the rear of the intake.
I have a N2O setup that will be used later for the max pulls at the track that you will see a nozzle on the 90* bend to the TB in the pics to come. I plan to mount the Meth nozzle 90-180* from the N2O nozzle under the tube.
I am open to suggestion as this is my first time to work with this configuration.
I plan to mount the tank and pump in the trunk and make a polished alum. cover for the tank to match the N2O bottle and Batt. box.
Here are some pics I have now and will update as the install happens this weekend.
