MindIfISmoke's? Built Part 3.
fiveohwblow
Flame Thrower
WA
The SINGLE benefit to living in this crooked ass lib state... Cool air.
Bleed that bitch Matt, and start whoopin on the locals.
JeremyH
3V Fuel Guru
Virginia Beach
Did you bench bleed it?(fill it with fluid before install) this is key from my experience. Also what clutch and in the pic looks like you were using a shim for the slave, did that go back in?
I have the exact same vacuum pump setup lol
JeremyH
3V Fuel Guru
Virginia Beach
Why did you add the shim did you add it form the get go? Is there preload on the slave?
JeremyH
3V Fuel Guru
Virginia Beach
Is the slave compressed against the pressure plate when installed or spaced away from it.
JeremyH
3V Fuel Guru
Virginia Beach
On my 3650 the slave never touched the pressure plate installed (zero preload). If there is too much preload this may be a factor in why it failed so quickly.
one eyed willy
Pizzle fo shizzle
Lakeland FL
I had to pump mine a few times each time I got in the car for the first week or so. I bench bleeded mine. Are you pumping the pedal with the vac on it? Seeing any bubbles?
Your suppose to take a few measurements before actually using that shim.
JeremyH
3V Fuel Guru
Virginia Beach
Yes, I drew a vacuum, pumped the pedal repeatively for 20-30 seconds then let it sit with the vac on it for about 5 minutes. Then repeated this a couple times.
