JLT's newe SUPER Big Air Intake for KBs and big Whipples testing and info
Tucker
VA
It seems we have been working on this kit for a year, but the fact is we finally found the time to get it done. As you know the Kenne Bell Stage 3 kits come with the Ford GT Supercar rubber inlet and KB MAF/Filter unit. So after tons of requests from Kenne Bell owners we designed a kit to fit the large twin 75mm throttle body of the Stage 3 kit.
A massive 5.5" at the throttle body and a hat size of 6" at the filter, this thing is huge. Available in roto molded plastic in 2 finishes, black textured or your cars exact body color or real Pre Preg Carbon Fiber. The plastic tubes are a full .250 or 1/4" think and measure 148mm ID at the MAF, while the carbon fiber tubes are thinner due to it's extreme strength it measures in at 155mm.
These sizes will support 700 to well over 1000 RWHP.
As a matter of fact, the guys from Evolution Performance installed one on Chris Cruz's 2011 5.0 which made well over 1000 RWHP and set a worlds fastest speed record running 8.99 in the 1/4. It can flow some air!
We headed up to our friend Brad's shop in Hampton VA, Horsepower Solutions to do some dyno testing on his 2008 GT500. It has the KB Mammoth stage 3 kit along with headers, killer chiller and all supporting mods.
After a couple pulls, Josh, the tuner at HP Solutions realized the MAF counts were very low, so we removed the Diablosport MAFia and got back to tuning. Basically the large size of the JLT allows the stock MAF sensor to gain range and work at a much higher HP level, tuners will love this.
Once the A/F was set, he added back in the timing to match the base line runs and hit it!
Boost picked up by about 1 psi resulting in a good gain across the entire RPM range.
Custom tuning is required.
Recommended for cars 700-1000+ RWHP
If you have our JLT Big Air Intake, there is no need to go out and get this. The Big Air will support 800-900 RWHP with no problem, we just made this to fit the large KB throttle body and saw that it could fit big Whipples too.
Pricing:
Textured plastic kits $399
Color matched kits $449
Carbon Fiber kits $549
All kits are IN STOCK and SHIPPING!!
We have kits available for
2007-09 GT500 with Kenne Bell
2007-09 GT500 with big Whipples
2010-13 GT500 with Kenne Bell
2010-13 GT500 with big Whipples
2011+ GT 5.0 with big Whipples
Here are some more pictures:
Mike K
WANNA BE FAST
Richfield, MN
I know some guys will wonder if your going be making a kit for the KB 3valves?
The other setups look like they move some air!
Tucker
VA
The kits are moving pretty good and we just saw this posted up on Facebook:
2011 Super Snake guys. We have been helping our customer get this car right since it was initially built by Shelby. You will be happy to know that we swapped out the Kenne Bell intake in favor of your 148MM unit Jay! Couldn't be happier with how everything worked out! As always, big thanks to Jon Lund @ Lund Racing, he's been doing my tuning since day 1 and is the best in the industry!
The car wasn't making the power it should, so the guys at Wolfpack Speed called and ordered the new Super Big Air in plastic and this was the result. Great job guys!:beer:
Thanks
Jay
