If you Drag Race, PLEASE weld your axle tubes.
TurboFocus
Welded my axles tubes today. it is not a easy task when you only have jackstands. I did big tacks in the 12,3,6,9 o'clock positions. then welded between the 12 and 3 o'clock position then went to the opposite side 6 and 9. Then the rest, went as smooth as possible without a lift.
Yagermeister
DFW
Any risk of boiling the fluid if you don't drain it first before welding?
Sent from my Galaxy Nexus using Tapatalk 2
TurboFocus
Aren't you supposed to wrap the weld to keep it from cooling too quickly?
Yes sir, its a good practice to do it on cast and certain times when doing aluminum. I did wrapped mine but i dont hear about others doing it, and theres being ok.
TurboFocus
rayS197
virginia beach, virginia
Mine were welded on the car and fluid in the diff. . Had a leak on C-clip eliminator and had to pull one axle to fix the leak. Nothing disturbing on the inside from the welding that I saw.
AJCrader
Glendale, AZ
What? You don't need both.
Better safe than sorry right? Being that I have a stick car, I plan to race a decent amount, and I am a worry wart when it comes to weak points in the rearend, plus in other cars I have broke a few already...just want to keep it from breaking as much as possible
You must be a government employee, I think. Your position makes absolutely no sense at all. More isn't always better.
Bmr4life
2005 GT
Atlanta
I say not both because you don't need both. But its your car and you've had bad experiences before so do you. Probably won't hurt anything other than your wallet.
