Bobby
turbo gt about to go fast
That is how I am doing mine.
The 4-port Aeromotive Pro-Series EFI that came with the Lethal kit.Which regulator did you use Flapjack
I couldn't stand the fuel pump running with they key on, so I did install a kill switch and put it in the cup holder (under the cup "spacer", or whatever the hell you call it).
Those may have been options in the beginning, but the switch works pretty good for me. It also works great for getting fuel out of the tanks and/or lines. Once in a blue moon though, I forget to turn it on.You can keep using the stock FPDM so to power the relay and keep that same feature as before, so it will go on to prime and stop, the thing is that this "priming" is lost and your crank times will be a little longer compared to having the pumps running all the time.
There is also another way by using the FP control lines of the PCM but I have not tested them yet as the FPDM method works great.
If someone wants to use that just need to power the relay coil (Vbat and GND, need to use both, specially the GND) with the pink and black wires that originally went to the stock pump, thru the 85 and 86 relay connectors.
Those may have been options in the beginning, but the switch works pretty good for me. It also works great for getting fuel out of the tanks and/or lines. Once in a blue moon though, I forget to turn it on.![]()
The switch is nice, but it is cool to have so many different options in the tune, too.Absolutely, I have installed switches myself so I can switch either pump independently but have done this to some customers cars and works great.
Sent from my Nexus 7 using Tapatalk 2
so on my setup you would be talking about using the fuel pump control lines from the PCM to activate the relay for the fuel pumps since I no longer have the FPDM?
Email me the info and I will check it out after I find my current issue on the car. Then we can post our findings after its been tested.Yes, if you want your car to be my guinea pig one more time just let me know. As I said, I have not tested but have the idea that this can be done thru that and some changes in the tune. Maybe, we can find that out.
And here is a 2 port setup run pre rails, not as popular as you have more of a chance for a pressure diffrential the farther away from the regulator you get on the supply side.
That doesn't look safe. LOL
lol, not a fan of that method myself either, my buddy has his 2000 gt 2v setup like that with an aeromotive regulator, it works though, at least the gauge by the regulator says it does anyway and he hasnt had an issue yet running 600rwhp... lol
And here is a "pump to a dead head" method where it dead ends at the rails similiar to the way the new cobrajet is setup. This requires a 4 port regulator.
http://www.lethalperformance.com/aeromotive-pro-series-efi-fuel-pressure-regulator-4.html
question about the guys who currently run return systems. What do yall see on the Fp gauge while pulling vacuum? I'm trying to determine what my fuel pressure should look like. I see 42psi on the fp gauge at idle pulling 12in of vac. I see that on the rail as well. Should I set my fp to 42psi when at idle or should I see 42psi with 0 vac. My return setup is: hat-3 to 1 y block-filter-1 to 2 y block-rails-fore f2 reg-return line.
You should set your fuel pressure without the vacuum line installed on the regulator. The other way to do it would be to turn the key to the on position without starting the car with the pumps running. Set the base pressure and tighten the nut on the regulator. Then key the car on and off a few times without starting it just to make sure the gauge at the regulator sees the base fuel pressure you set it at. Once that's been verified you're all set.
Jared
