Installing a paxton novi 2200.
Wnt2gofst
Banned
Columbus GA
youd be surprised how much surface area you cover with a screen
if you want to do it with a screen, you should make a cone shape that is at least 1" larger, to comensate for all the wire / mesh
that'll get after it!!!
When I go to the trackk I pull the screen off. :)
stang8psi
Slower,Lower Delaware
or you could just do a flat small filter ! and wnt2go do you have any problems or noticed any problems with the oil seperator vs the pcv that is in the paxton kit?
Wnt2gofst
Banned
Columbus GA
No issues. and had this setup since bought the car new. Day bought it got the blower put on. 15000 miles later still perfect. Car has made 700whp+ on stock engine, drove cross country twice. And several 250-400 mile trips. Along with least 150 track passes and top speed pulls.
from the famous tapatalk.
stang8psi
is there a benefit to using the can over the pcv it comes with? cause I have the same setup Boss mani, and 2200 and I wanted to run the catch can, but was unsure if it can be used!
Wnt2gofst
Banned
Columbus GA
Same as n/a. Don't get all that blow threw oil going into intake manifold.
gizmo5
Italian between my legs
Hey man was good meeting. Didn't see you when we rolled out. Again want any help with install just let me know. The TX crew and my self are always down for builds and work.
It was good meeting you to man! I cant wait to make my engine look like your engine bay. :beerchug2:
And your car was sexxay... just sayin... :beerdrink:
gizmo5
Kenaizer helped me out with this little bit of info, wanted to make sure everyone else knew it as well.
If you have a 2013 and are installing a Pax/Vor, it requires zero bumper trimming. The only thing that needs to be trimmed is the under tray for the pipes.
BUT, if you have a BOSS or a Track Pack GT, get ready for some cussing and modifying... Without instructions... PM me if you have one of those two and I will help you avoid a bunch of headache and save literally HOURS off of install time.
gizmo5
PM inbound, call me or text me if you need help
gizmo5
Double check the brackets bolts. Mine were in but loose. Also, I had to route my belt through because it came in a plastic bag, not in the bracket. Wasn't hard though, just do it one pulley/bolt at a time so you don't get them mixed up.
onebadgsx
Houston, TX
Well only put in about 3 hours. Obviously did all the tear down then got all the coolant hoses re-routed. Just have fan mod left on the coolant system. Bunch of tedious crap on the relocation of stuff. Cant wait til i get to the actual blower install. I hope to finish up tomorrow.
onebadgsx
Houston, TX
Another 2 hrs got the bracket, blower and intercooler installed. Started hot side piping as well. Should be all down hill from here.
