Installing a paxton novi 2200.
gizmo5
Italian between my legs
I want 650 at the wheels. Thats kinda my final benchmark and I don't see it happening unless I pulley down
gizmo5
Juiced66, whats your setup right now? And what's it putting out?
Wnt2gofst
Banned
Columbus GA
With the 3.6, 18.5* of timing. Boss intake, I made 680whp on my street setup an 713whp on my drag setup. Heavy 20's vs light 15's.
Juiced 66
Lake Jackson (Houston)
Novi with 3.60
JLT blower intake
BOSS intake
BBK long tubes
BBK off road x pipe
Magnaflow cat back
Aluminum driveshaft
Those are the mods that I have besides suspension stuff, Jim from JDM is down here right now, and he's making me a new tune because the drivability of my car wasn't that great with the tune from my local guy. I ran out of mass air yesterday at 6500 so I'm trying to get my hands on a new mass air housing this morning so we can get it dialed in before he goes back to jersey. It made 620 at 6500 rpm. Car was at just over 8 lbs of boost with 12 * of timing on 93 pump gas. Once I get the mass air changed out and can spin it to 7200-7500 and put another couple degrees of timing I'm sure it'll make 650 or so on pump gas and be safe.
gizmo5
What is your fuel setup? Injectors, BAP?
Kenaizer
Denver
I'm on the 3.6 pulley Beefcake Special and a conservative Lund tune on 91.
Wish there was a dyno and a track nearby.
gizmo5
Im gonna run the 3.6 with 93, and I want Lund to push right of conservative. Just till I hit 650rwhp. Then I will be happy. :thumb2:
gizmo5
A 3.6" pulley can put you well over 650. I'm using a 3.6" and even if I was to stop my pull at 7000rpm I'd be over 700.
That's what I thought. I was thinking hitting 650whp would be silly easy for any tuner with the setup I mentioned.
If Lund can't get me to 650+ on 93 pump, with a 3.6" pulley, ID1000's, BAP, an open filter, 3" ORH, and winter air... Well, there's something wrong. :crazy:
onebadgsx
Houston, TX
I didnt say he couldnt... but dont be surprised if he recommends running torco or race fuel
Wnt2gofst
Banned
Columbus GA
Yep. As stated I'm using it and made 713whp pulling to 7500 on stock headers, off road x pipe. With some long tubes I could make more and sooner.
Even on my the street setup making 680whp cause heavier wheels. Add LT's and it will make more and sooner.
squidzx6
island park new york
Some advice? Go with his "Beefcake Special"
I ordered the full kit with a Lund remote thinking that's all I would want. Well, I was wrong... So basically I wasted money on the 47lb injectors, the paxton tune, and so on. And now I'm ordering the ID1000s and a BAP because I want more. :crazy:
Wish I would have just got the tuner kit "Beefcake Special" setup from the start.
Already planning on it plus I want polished with the jlt
gizmo5
Buy a spectre 4"X6" aluminum tube, and any 4" base filter you want. $50 instead of $123456 whatever brand.
I copied Stang910s, just used a diff filter.
Here's mine for an example, I went with an Airaid Synthamax Dry filter
http://www.spectreperformance.com/i...inum-tube-4-o-d-straight-6-long-polished.html
