Gotta be able to read what he means and not what he types.![]()
I know huh? I put the weird part in bold and he still didn't explain what he meant to type
I'm assuming that he had to replace it, but ......
I'm assuming that he had to replace it, but ......![]()
It perfectly leveled. Maybe axle side is about 1/4" lower.
I hate the fact that my Che relo doesn't have extra hole for the adjustability.
Will I benefit from BMR at the lowest setting?
Yes, you need relocation brackets...
Yes, having your control arms pointing "up" towards the axle increases roll understeer and screws up your anti-squat geometry.
Thanks. I think I'll go with relo brackets to lower the axle end of the LCA a bit. I emailed MM (the manufacturer of my control arms) and they recommended the same thing:"There are two ways to fix this.
One is to relocate the differential mounting point down, the control arm should be level, or to raise the car back up to make the arm level.
Both ways will help with putting the power down out of a corner, raising the car will get you more bump travel and a better ride.
If you are having traction out of a corner issue, try pulling the rear swaybar off. We found after some adjustments, the car puts the power down better out of the corners, and has a SLIGHT push to it if over-driven into the corner."
Without a rear bar either, expect the car to not want to launch as straight as it does (?) with a rear bar. Unless you're running something like a ladder bar setup, you want a rear bar for the strip - that's why the aftermarket sells these huge diameter "rear antiroll bars". Technically, more rear bar = less roll = less axle steer = straighter out of the hole. Even the bar's weight is in the right place (rearward and low). What's not to like? Why would you want to go the "wrong" way with this?Always read going without a rear swaybar wasn't a good idea...
I only have a rear sway bar, front is gone. wonder if going without the rear will be an issue.
wanna sell it? do you think it will match up to the steeda cai? the sheild is not a big deal cause i've got to make a new one anyway to seal up around the opening in my hood.
Got the Whiteline brackets today!
Just a quick tip... and it's kind of a DUH thing, but do not tighten all bolts before putting them all in (counter to what Whiteline's instructions say). I couldn't get the driver's side rear LCA bolt through the bracket after tightening the bracket bolt and the panhard bar bolt...
All those bolts should slip right in if your axle is centered.
