GrabberBlue5.0
Gold Member
Koni advertises them as useful for stock ride height to moderately aggressive low ride height
From everything I have gathered on this thread as well as what I personally run on the street, get the strt. If you rarely track the vehicle (you said it's a street car) then the yellows would be overkill
but I do plan to make some autocross events later in the year once the suspension is dialed in.
But why pay extra if you dont need the adjustability? I run the str.t's with eibach prokit springs and its a nice setup with a real nice feel. Not too hard or soft. Sportline springs though...not sure..
Sent from my SGH-T999 using Tapatalk 2
Ive tracked with the SRT.Ts and have nothing but good things to say. They are not a competition or an everyday track use strut/shock, but hold their own for a few events here and there. Will greatly reduce brake dive and have pretty good damping. Worked well with the Vogtland spring I had, which Steeda gets their spring made by, so you cant go wrong with Konis/Sports. I can say they do feel like yellows on full soft, so if you can spring for it spend the extra $ for the yellow.
JMO
How do you know you wouldn't make use of the adjustment???????If you took a quick poll I think you'd find that those that have Koni Sports generally do not opt to run them at full soft (which is most like STR.T's). They could, if they liked that better. But it's not common.
FRPP dampers... pretty well suck. Ride like ass, have way too much compression damping and to a lesser extent too little rebound IMHO.
Yeah, I think that's a very fair and honest assessment of the difference all the way around.
FWIW some Steeda springs are made by Vogtland, not all... and those that are do differ a touch from the V-spring.
The yellow on full soft won't fade out like the strt though.
What do you mean?
When a damper moves it generates heat. If it generates enough heat it will froth the oil inside the damper which is the equivalent of brake fluid boiling. Your brakes fade...your dampers fade from the heat too.
The koni yellow at full soft settings, which is the same damping as the str-t, will not fade as fast as the str-t. I got my info from Koni, so whether it's right or wrong I don't know, but that's the skinny.
Do you need to worry about it? Depends on what your plans are for your car. Autocross or road course driving are gonna generate heat. Bottom line is Yellows blow the STR-T's out of the water, but STR-T's are way better than stock dampers. If anybody is experiencing damper fade around town, chances are they are running from the police. That would be about the only time you would worry about it on the street. Which is virtually never.
Lots of good info here, thanks guys.
