2013 GT nitrous install
NoSlo5oH
I have been working on this install for a few weeks now. I wanted things to be a certain way, so I decided to piece my kit together and perform the install in stages, while keeping within my budget. I think it's going well overall, but I have had to cross several hurdles along the way. My latest hurdle is nitrous and fuel lines from the nozzle to the solenoids. I initially ordered lines that were too short. I also feel that I need 90 degree elbows on one end of the lines to make them more flexible for my application. Here are a few pics.
NoSlo5oH
I don't know why I always experience problems loading pics, but for some reason I can only download one at a time.
NoSlo5oH
Test fitting everything is very necessary to get things right. It has helped me to discover several things that needed or still need to be changed.
NoSlo5oH
Nozzle adapter and nozzle.
NoSlo5oH
Fuel rail adapter and Hobbs switch.
NoSlo5oH
Fuel rail adapter and Hobbs switch installed on fuel rail.
NoSlo5oH
Miscellaneous pig tails and harnesses that I made.
NoSlo5oH
I had to trim the cooling fan shroud to gain clearance for the nozzle when installing the intake tube (nozzle slightly touched fan shroud and didn't go on as easily as I would have liked it to).
NoSlo5oH
Battery tray with relay and fuse holder mounted.
NoSlo5oH
Pic of solenoids mounted on bracket. Note: This solenoid bracket cannot be used without the spacer or a plate kit.
NoSlo5oH
BTW, the guys at Nitrous Outlet have been great. I can't count the number of times that I have PM'd or e-mailed Neal with questions along the way. He has always responded back in a timely manner with answers to all of my questions...Now that's what I call outstanding customer service! I am happy that I chose to do business with them.
5lho
What tune you going to run? You really can't spray a 5.0 safely without one...unless it's a 1988...I shot 125 through one of those no-tune, dry :)
onebadgsx
Houston, TX
I ran a wet shot. Plate kit from n2o outlet for a year or 2 on my 2012 car.
When tuning these on a wet shot. The ecu will correct the added fuel by the wet nozzle causing the car to be leaner than you want.
Fyi. Dry may be a better set up
NoSlo5oH
How did you overcome the fuel issue? What size shot did you run? BTW, I will be running a Nano system too. I don't plan on exceeding a 100 shot and will be running colder plugs with good fuel when spraying. As much time and effort as I have in this install, I sure don't plan to cut any corners.
Godzirra
Asian Idiot
Bristol, TN
They have to command the extra fuel in the tunes.
