JEWC_Motorsports
S197 Junkie
Waiting on BMR!!!!!!!!!!!!!!!! Kelly is BMR going to really make me put another brands component on my car?
There won't be more than 50 votes for yes.![]()
This thread is 20 pages.
Looks like a Cobra Jet unit.
Just a tad bit more than welding or a brace.
Sent from a Galaxy S3
You wouldnt happen to have a link to those rotors now would ya?
I don't know if the CJs use the Strange 9", but that's all it is. A bolt in Strange Engineering 9" from an article 5.0 Mustang Magazine ran about three years ago.
Sharad, you're an asshole...
I got a Currie unit with 35 spline axles, spool, and all of the brackets, etc, in the stock location so it was a simple bolt in. I got some options though, so it ended up being $2600.
The strange brakes are sweet. I have them on all four corners. The billet calipers are much smaller so you can run any backspace wheel and they clear. I never pull the chute either and I run 156-158 mph. However they are not meant for street use.
Installed the che. It required drilling 4 holes. The cover studs are a little short and will be replaced.
The plan is to test it out on Friday at a test and tune. I believe it is absorbing some road noise because todays test drive seemed quieter than normal at highway speeds.
All in all it wasn't too bad of an installation.
CHE sells the longer studs for the girdle integration.
http://www.cheperformance.com/prod-267.htm
Give them a call and I bet Chuck will get you squared away.![]()
+1, Chuck is awesome.
Did have relocation brackets Bruce? Pics looks like you removed them. What brackets are you gonna go with?
