Status
Not open for further replies.
brianadams03
Madison, MS
New pb:
11.864 @ 120.25 w/ 1.767 60'.
Mods:
--3.73's
--Boss 302 Intake Manifold
--JLT CF CAI
--93 Lund Tune
--GT500 ab's
--Lethal O/R X-pipe
--Mach 600 Clutch
--SR Short throw shifter
--Dark stars w/ Hoosier QTP'S 27x10.5x15
Brezick
Yinzer
New best....so close...
1.61 60'
4.54 330'
7.02 1/8th
98.06 1/8th mph
11.000 1/4th
124.52 1/4th mph
Boost was increased to 15lbs.
Bloomfield, NJ
New personal best! 12.18 @ 112 mph car # 6056 below
Stock airbox, Stock exhaust except for GT500 mufflers, and stock 3.15 gears, and stock factory tires.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
New best...into the 10's:
10.7481
with a backup of 10.86, also a new best for me before the 2nd run.
- Cubic inch displacement (CID) of engine -- 302 (4.6 stroked to 5.0L)
- Type of transmission (by model number) -- 4r70w
- Size and Manufacturer of power adder, or N/A -- Kenne Bell 2.6
- Pounds of Boost, of N2O shot (or both if applicable) -- 18 psi
- Rear Gear ratio -- 3.73
- Make and type of tire -- M/T ET Street slicks
Fabman
Children Of The Corn
Pleasanton, Ca.
New Personal best:
http://youtu.be/RkTK3pmoW5k
- Type of transmission (by model number) -- 5R55s
- Pounds of Boost -- 17 psi
- Make and type of tire -- Hoosier DR's
2011BaseGT
Stock Boss Laguna Seca on MT Street Comp Radials. I believe I'm the fastest stock Boss on radials!
12.17 @111.75 60ft 1.83
Brezick
Yinzer
Another new best:
increased boost to 18lbs. Got REALLY hot so it died a little on the top end. Hoping to add a meth kit and get a 10.5-10.6 on a clean run.
1.45 60'
6.83 1/8
99.96 1/8 mph
10.84 1/4
121.72 1/4 mph
Fabman
Pleasanton, Ca.
Another new best:
1.45 60'
6.83 1/8
99.96 1/8 mph
10.84 1/4
121.72 1/4 mph
Good run-great 60' time....What trans and converter are you running??
Brezick
Yinzer
How well do those 127550's behave on the street?
They are fine after driving for a good hour, but cold starts and first 20-30 minutes of driving are pretty bad even with letting it sit and warm up for 10-15.
They also sound really nice.
dysan
Dis-Member
Williamstown, N.J.
New best today just testing out a revised tune to make sure the car wouldn't go into failsafe anymore with the 3" pulley.
Engine is .010 over stroker (300ci)
10.3:1 compression
FRPP Stage 2 heads
Comp 127300 cams
Edelbrock E-force 16psi
4R70W trans
4.10 gears
M&H 325/50/15 racemasters
60' 1.434
330' 4.232
1/8 6.550
mph 107.91
1000' 8.574
1/4 10.259
mph 134.50
Here is that slip and followed by one from when the car went into failsafe around the 1000' mark
Fabman
Pleasanton, Ca.
10.3:1 compression
FRPP Stage 2 heads
Comp 127300 cams
4R70W trans
4.10 gears
60' 1.434
330' 4.232
1/8 6.550
mph 107.91
1000' 8.574
1/4 10.259
mph 134.50
Wow, impressive....we have similar setups but you're going MUCH faster. I must be missing something....
Status
