S&H Turbo Kit Build
Makdaddy
I am Dysfunctional
South of Chicago
Mounted hope this works and can get to it.
Is your bottom pipe above the Swaybar? or below ?
06stangia
Iowa
I don't have my turbo yet so i just have it sitting there. Does anybody know does it go above or below? Bobby, Jeremy, Greg?
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Hard for me to answer as the 2 turbo installs I have been involved in had the FSB removed.
one eyed willy
Pizzle fo shizzle
Lakeland FL
Looks like either way....
Red car above you can see the sway bar revolution bracket in the bottom right of the picture, putting the pipe above the sway bar.
Black car above has it below with no relocation brackets.
Makdaddy
I am Dysfunctional
South of Chicago
Ok I am below like Joshs picture, so i should be ok, we are fabing support brackets and mounts for the intercooler
Makdaddy
I am Dysfunctional
South of Chicago
i did have relo brackets on the car in those pics too
10-4 I have the swaybar relocated down and the pipe swings under it like in your pic
i have good clearance for the hood.
I would think that if the pipe went up any higher in the engine bay the hood might hit
OP you may want to check that, if you are that high going over the swaybar then you may be too high up in the engine bay
06stangia
Iowa
I was looking in my kit and found that I have 4 gold bolts and no studs to mount the turbo is this going to be a problem?
Bobby
turbo gt about to go fast
just out side of charlotte north carolina
Looking good. You want get studs just bolts and nuts to hold on the turbo. Waiting on jeremy to return to send out your fuel stuff and i am waiting to hear back from comp on your turbo. I do know that they have charged my account so it is either close or it is done.
Hiltsy845
Have heard mixed reviews about Joey. Myself, if I was doing a dyno tune I would probably take it to Dynosport in Lincoln. I have seen and heard nothing but good things about Dan. My first choice would be to have Lito (Manuel) tune it based on reputation and convenience, but that's just me.
