luv2cheat
the control arm will be at an angle depending on where you have it installed on relocation brackets. take a plumb bob at each bolt and mark the spot on the floor front/rear. measure the distance on the floor (it will be a fraction of an inch shorter than the actual control arm length).
I could not use a plumb bob at the upper rear mounting hole. Since it's on top of the axle the plumb bob won't hit the ground.
Now what? Am I missing something obvious?
