2013 GT S&H Performance/On3 twin turbo install-long read!
Bullitt3478
Fernandina Bch. Fla.
Sorry to hear about the issues, can't lie it does look damn good under the hood though.im sure there's plenty more power in it once the issue gets worked out.
I can get the HPX maf if needed but I would like someone smart tuning wise to tell me if the 02's not working right would affect the maf.
It's a frequency based maf. HPX isn't going to work unless they are offering a freq based maf, The one I'm familiar with is voltage based. Like honey badger mentioned Pro M has a frequency maf. I've read that the wideband o2 sensors won't work very well with a turbo under boost because of the backpressure so wot needs to rely on the maf xfer just like older motors.
You get to learn all kinds of new things about the coyote. I think they are just going to be bumps in the road.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
The HPX is for the coyote; Chad from On3 pegged his as well on his 2011 automatic...they ain't cheap though, $469 with a $69 core charge once the stock one is sent back.
JEWC_Motorsports
S197 Junkie
How are you pegging the maf? Serious question. Many others with much more hp dont peg the maf.
Wnt2gofst
Banned
Columbus GA
You have to know how to extend it. Guess its hard on coyote. Im on stock one now thanks to lu d talking to my tuner. After bbr told me couldnt be done and ordered pro m. Which at time was only one out.
from my S4 in your sisters bed
Mustang-mike
Shwetty member
Florida
Yikes sounds like a nightmare, but like others said your going to hit bumps in the road on the first try, it's all about how to get past them.
stang8psi
Slower,Lower Delaware
Are they the same Bov and wastegates chad offers (on3)(Chinese)?
Also just playing devils advocate.. Sounds like some of the problems are install related! (powder coating issues which lead to o2 problems which these cars are wideband read cars and is probably causing you issues I am sure)
And I am sure your oil less turbos are good, But oiled ones have produced power and will produce tons of power, When Installed correctly, It's proven time and time again.
What maf did you use? I would ditch the one chad sells in the kit and either make (if you guys can fab some aluminum) a 3.5-4" pipe with a air straightner and put your stock maf back in place, or possibly try a pro-m frequency maf!
There are pros and cons with every FI kit out there! but surprisingly I have heard once the little issues are worked out (install) these kits are running good, and putting out good power when tuned by a good tuner
so stay positive and just re trace some steps that are and could in the future cause your issues..
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
May have been a nightmare but it sure looks awesome!!!!!!
Wow!!! Those under the hood shots are sweet. Now light the wick on it!!!!
