I'm running a 2007 Shelby GT in ESP. The suspension is pretty well developed with Koni (yellow) doubles, watts link, UCA, adjustable bars, camber plates, T2R, 18x10.5 rims with 315s. The car handles well, but I'm trying to turn it up a notch.
Sounds like the Strano ESP Recipe
(TM), to the letter. Have you asked him for help to go further? I don't want to step on Sam's toes, and I won't poo-poo his set-up advice. He has a lot of National championships, there is no deny.
But ESP has ratcheted up of late and it is going to take a lot to dethrone Mark Madarash's 3rd gen F-body build (above). We run against him locally and he is brutally fast, and always developing the car (16 years and counting), and has 7 ESP championships in this lightweight Firebird. Mark was at a local event last weekend and had a new stuff he was testing before Nats, once again. If I were a betting man I'd wager he will pull off #8 this year, too. His car CAN be beat, and I think the S197 is the car he fears mos. But it ain't gonna be done in a street car - it will take a serious effort, lots of testing, and a healthy budget.
So with that said, I'll go ahead and take a crack at your questions. First, I'll start with some questions of my own:
- What springs/rates are you running?
- What UCA are you running?
- Do you plan on attending National events and the Sol Championship? Have you done so before, and if so, how did you do?
- What is yoru budget/level of competitiveness? Will you sacrifice street car amenities to go faster? And are you willing to pour more like $1000 or up to $30,000 into the car?
For my next mod I've been considering upgrading the control arm bushings. Can anyone make a recommendation on something they know works well for autocross?
Well in the rear you cannot change out the Lower Control Arms in ESP class, nor add LCA relocation brackets, which is a real shame. Only thing you can do there is aftermarket non-metal bushings in the stock LCAs. I suppose it would help, but not as much as a properly designed arm with spherical or elastomer bushings.
As for the front LCAs, there might be some OEM arms from the update/backdate allowance, but I'd just recommend doing the bushings in the OEM arms.
http://vorshlag.smugmug.com/Instructions/Eibach-poly-LCA-bushing/
We stock and sell
this bushing kit ($62) for the S197 and it is perfectly ST and SP legal. The labor to install them is a bit of a hassle, but if you have an afternoon to kill and a good set of tools you can do it. Makes a tremendous difference in toe control under braking and camber loss under suspension loads. HUGE. And on a pre-2011 S197 it doesn't cause any issues with the EPAS electronic steering, because the '05-10 cars don't have that mess.
Thanks for any suggestions you may have.
There could be other "low hanging fruit" that might make you faster in ESP, of course. Things like:
- Lightweight AGM style battery (an easy way to drop 25+ pounds)
- Lightweight, fixed back racing seats (a bit pricy but allows a 50-75 pound drop + a LOT more driver control)
- Weight loss by any means (A/C, radio, emissions)
- Wider wheels (18x12") and wires (335s or 345s) with flares
- Cold air intake kit, Throttle Body, aftermarket Intake Manifold
- Full length headers, lightweight exhaust (for lower weight and more power)
- Front and rear aero work (within the tight confines of ESP rules)
- Lightweight brakes (aftermarket light brakes in the smallest possible S197 diameters)
- More serious monotube dampers and much stiffer spring rates
- A Boss302 motor swap is legal, and definitely makes a lot more power
- A torque arm set-up is legal, if a tick costly, and one of the only ways to work around the ESP rules that ban proper LCA relocation brackets. Might be worth testing, but only in SCCA classes that don't allow $100 brackets that fix the rear geometry from a lowered S197
There are so many things you
can do, but do you
want to do them? It all depends on how serious you want to be in ESP.
All of these mods have compromises, of course. But to win ESP at Nationals takes a SERIOUS effort. One of our customers took 2nd at Nats in a 2006 GT (top left) last year, but it had 1000# springs, ASTs, no A/C, 335mm Hoosiers, and was a serious build. We took 4th in open and 1st in ESP-L, in a emissions legal, full weight street driven car - but 4th ain't 1st.
If you are just looking to go faster at the local level, that's a whole different ball game.
The ruleset in ESP restricts some pretty common and beneficial aftermarket parts, of course.
Once we stopped building around SCCA class rules and left the ESP class our car got considerably faster, but now we have to autocross in StreetMod, which is a bit nuts. Our car is really set-up for track events (NASA TT) but it still does really well in autocross, though. After we made a recent spring rate upgrade (+45% in rate!) on our '11, I want to go back and do another autocross, to look at the relative PAX times again. There's always room to improve.
Feel free to give us a call at the shop to discuss your car. We don't mind phone calls or emails asking for set-up advice. 972-422-7170, ask for Terry or Jason. Or e-mail us at
[email protected].
Cheers,
