Installing a paxton novi 2200.
DSargent09
Get iT!
Helpppppp..... Im having trouble installing the id1000s. I ordered the beefcake special. Does it not come with the fuel rail spacers?? I removed the 4 OEM ones but don't have anything to replace them with..... What do I do?!?!?
Kenaizer
Denver
Yeah you literally plug them in where the stockers were, and plug the connectors into them just like the stockers.
DSargent09
Get iT!
Ok nvm I got it. That's what happens when you're working on it at 3 am. You stop thinking clearly
Kenaizer
Denver
Yeah the only thing you do to the IDs is pull the plastic caps off and put them where the stock ones were.
DSargent09
Get iT!
Anybody know how to install the BAP it comes with no directions and I can't find what I need online. I am in the process of searching this forums as I type.
mikeyfitz
Houston, TX
You need to expose the wires and find the purple with green stripe wire.
Cut that wire and basically installing the BAP in the middle.
From the BAP - Power/red w Fuse, connect to front car side of purp/grn wire
The other red wire, connect to the trunk side of the purp/grn wire
Black is just ground.
DSargent09
Get iT!
THANK YOU. I am now done. Working on the Boost gauge then tune.
DSargent09
Get iT!
Ok, where should I splice in for the boost gauge wires. I got the thing hooked up to the BOV line or what not. I just need to know where to steal power.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Best place is to tap into the headlight switch since most people either have the triple pod gauge or the single Roush vent pod to the left of the steering wheel.
gizmo5
Italian between my legs
The BAP, and everything else is in this thread lol. This is the Paxton Bible... ;-)
Read my son, and the boost shall set you free. ;-)
