Sinner....(Sactown F1R) build
muztangman93
Indiana
I tell people about mine running the 27lb pulley and putting out 17psi and nobody understands it lmao. I installed my wot box took me a little while but wasn't hard also did my own meth install not hard as well ended up removing front bumper and putting the pump by the drivers side head light. I was having a few issues with meth running down into the piping after letting off the gas. So it would then blow all over the maf sensor. Once that would happen It would go full rich and fall on its face if I tried to pull boost. After cleaning it the car would run correctly again. I think Ive got it coming on at the correct amount and time now haven't had an issue in a little while.
Sinner
Plano, Tx
I've read up on this but I can't seem to come to a conclusion.....
Should I vent crankcase pressure or use catch cans with this set up?
05stroker
Never enough power guy!
Bullard Tx.
I use breather cans. If you mount them near the air filter the fumes will be drawn in.
Sinner
Plano, Tx
Billy, do you have any pics of your set up and what brands cans do you have?
05stroker
Bullard Tx.
They are Moroso cans with breathers on top. I have -10 fittings on them with -10 line coming off the valve covers. I will try to post a pic tonight.
Sinner
Plano, Tx
Ok, panic mode.....
Changing piston/compression to 13cc /9.9:1
GB10 is putting the motor together and calculated the flat top pistons to be 11.7:1 and I'm just not going to risk not getting to my goals on pump gas due to too high of compression so I'm changing out the pistons.
So, ill have some new 3.7" big bore flat top pistons for sale soon with SS rings and pins.
Sinner
Plano, Tx
I'm researching which pulley I need to get near max blower speed to have power come in early and waste gate the boost over 17-20psi... Just depends.
I'm not sure the size of the " ATI Super Damper" so I can't calculate the blower speed with the calculator... Does anyone know the diameter of the ATI?
Sinner
Plano, Tx
Ok, I'm a dumb ass.... The 12 rib lower pulley from procharger bolts to the ATI so does anyone know the diameter of the procharger lower pulley?
muztangman93
Indiana
Correct. Im surprised no one has measured one. Procharger should know the measurements
